Im having an issue with displacement.
Its really rough and jagged for some reason. The map im using for displacement is a high res png file so i dont know why this is happening.
Ive tried setting the screen space units to 1px but it still looks jagged.
Does it looks like this in IR only, or also when rendered normally?
What is the expected look?
Can you share the scene, or at least the displacement map?
On the other hand, there must be something wrong with your png - with Corona bitmap it takes 10 times longer to calculate displacement than with native bitmap loader. Can i use your texture to report this behaviour on mantis, because i can’t replicate that issue with my textures?
Ive remade my geometry in a fresh scene, all seems to be fine now although the edges are a little jagged which is to be expected with displacement i guess. I have no displacement calculation problem like you have. Although i do have a weird shading issue where the middle strip of the displacement map renders strangely (see attached)
That shading error could be because adaptive displacement allocates very few triangles on completely flat surfaces. You can check that by assigning CoronaWire map to diffuse slot. Subdividing geometry before displacement could help to fight that.
That’s strange, can you confirm that the same texture that you’ve attached few posts earlier does not increase geometry preparation times drastically if loaded through CoronaBitmap with default filtering settings (bulr - 1, interpolation - bilinear (faster))?
Can confirm coronabitmap takes an inordinate amount of time to calculate displacement. Max bitmap loader is pretty much instant. Corona takes about 15 seconds.
I think all of this is rather expected because of steep edges in the displacement map.
I used gaussian blur with 2px value in PS, and here is the result.
Further investigation reveals why displacement calculations are so slow with CBitmap (but only if it’s set to bilinear interpolation). I am not really sure why this is happening, since the white area of the bitmap seems to have 255 white everywhere when checked in PS. This is easy to fix using an output node (clip darkest and brightest areas).
