We’ve been having this issue quite a bit recently and it’s leaving us pretty much stumped.
Here’s a .gif to show what I mean, these are just 5 frames in sequence from an animation (excuse the quality, early test):
Every now and then, a frame will get rendered as if the camera is rolled to the right slightly, sometimes it goes a little darker too. Then it goes back to normal.
Probably shows up in 1/200 frames, and isnt caused by just one machine - most of our farm has done it at least once now.
Happens with standard cameras and vray cameras, so i dont think it’s anything to do with that.
I’m sure I’ve seen something like this before on another forum. It turned out that some of Max’s animation controllers were better than others at interpolating accurately between keyframes.
Nope - it’s completley random. In that path it happens twice near the end, but i’ve since rendered those frames again and theyre fine. The first time I rendered it for a test it happened once, near the start.
We’ve had it on 4/5 different projects now, and from what we can see there arent any patterns to it occouring. All of our farm machines are exactly the same spec too, they were all bought at the same time.
You can try to upgrade to V-Ray SP2 and see if the problem persists; there was a similar issue that was fixed, although from the images above this looks slightly different.
