Odd Shading/Reflection Pattern ?
someone`s probably seen this before.
Was using CAD data but also created a tube next to it to test (on the right).
weird black patterns.
Corona Sun, reflect map in environment channel. Not much else.
Converted from Vray.
Using Alpha 4
cheers
Higgles
Can you upload the scene please?
Sure,
stripped out a few bits because of heavy cad. still the same.
did a couple of test and I think it`s the same Scale issue I had before with the environment map going weird.
I attached the camera, objects and light to a dummy and when you scale it it gets worse/better.
Issue is how do I know where to work scale-wise ? 3dsmax tends to be a bit flexible on those issues unless you`re doing strict architectural stuff.
attached.
Scaled up 10000
why are my scales always mangled :cool_button:
BC_test_Corona.zip (181 KB)
Fixed (was unrelated to envmap)
