office-market building test with Corona Render
Golomb Architect’s office-market project in old city/
Corona render,SketchUp for modeling,3dmax2017, ForestPack 5.41,no post,only CIE/
After quick completion of project for client in Vray 3.6 - I decided to make some /more thorough and calm’s tests :)))
/- in last DB-16/03- of Corona render with same model.
As always much faster and more convenient in the settings materials, composition, lighting and better in quality,
but very much more time for final render resolution 4800/3200 and higher/,
and much more memory usage in render process////The saddest is that with this absolutely nothing can be done, unlike Vray with fakes and settings///
Unfortunately still can not be using for fast commercial work:(, only for “home” usage :)–/ in our situation “from today to tomorrow with 6 cameras view’s and lot of corrections and test’s in work progress from architects”/:slight_smile:
Vray----4 comp i-7 5820k and one i-9/32gb mem all comps/ ----------- res-4800/3200-- 12-min/ without DeNoise–mem usage 12 gb /with 2d mapping displacement for ground texture/
Corona-----4 comp i-7 5820k and one i-9/32gb mem all comps/-----------res-4800/3200–2 hours — 5%noise+ DeNoise filter—mem usage 21 mb, /scene,materials and lighting build as new project, not simple converting via script and without using displacement at all
/unfortunately could not use Corona Scatter for grass and plant’s because this not support scattering
on splines and surfaces simultaneously, and many,many other convenient thing’s from FP /Correction of size and collision distance separately for instances ,changing probability for several instances selected with /Shift/ at once , very fast and true - without additional playing - lagging and freezing/ Camera angle view clipping , edge detection and etc.:frowning:
and this is not our heaviest scene at all:)
Close-up
