Offset U+V
Hi all
I noticed that if you position a texture using offset U and offset V in the material tag, the correct values will be times (-1) of what you have set there.
Example
this values are the correct ones for my editor/preview.
If I render it like this the mapping is all messed up. If I put a - in front of the values ( -63,1% and -84%) I get the desired output in the render. (even though it looks messed up in the editor now :wink:
bboo
Hi, I tried this and it seems to be correct. Can you check it in teh newest daily build please? Thank you :slight_smile:
