oh my CoronaRenderer dot what????!!!!!!!!!!!!!!!!
everything is guessssssssssssssssssssssssssssss
show renders.current???
gets some parameters,but,all guessSSSSSSSSSSSSSSSSSSSSSS
You shouldn’t lick the toads.
renderers.current.reset_settings
– Unknown property: “reset_settings” in CoronaRenderer:CoronaRenderer
– Unknown property: “resetSettings” in CoronaRenderer:CoronaRenderer
– Unknown property: “reset” in CoronaRenderer:CoronaRenderer
Reset settings is in a static interface, use CoronaRenderer.CoronaFp.resetSettings()
And this is your last warning, watch the language/attitude towards other forum members!
Out of interest, do you have any documentation on maxscript and Corona?
one questiong …one answer…
what a mysterious~~~
what should I say…thankkss
not yet
Thanks anyway. I managed to do most of the things I needed without it.
So, what’s going on around here..
little afternoon rage :wink:
Why can you just make a default corona render ‘rps’ and revert back when you need to.
help~~~~
Why don’t you just click those buttons and see what they do? Most of the things you marked are pretty obvious…
I need these codes write in my scrits…so..
btw, you can get name of every action/parameter using macro recorder, right?
Not the render setup window stuff.
I do that,but no response…
use
showproperties renderers.current
and you’ll get a complete list of all settings that have a maxscript command, you just have to figure out which is the right one.
DeadClown~
thanks
but “showproperties renderers.current” == “show renderers.current”
some codes of renderSettings are still do not show me,
e.g.
“reset settings” in “Actions”
!!! -------------------------->>>>>>>>>>>>>> CoronaRenderer.CoronaFp.resetSettings()
WHERE SHOULD I GOT THIS!!! USE “showproperties renderers.current” OR “show renderers.current” ???
…He was able to read,write and to make print screens…but not very convincing in expressing his fellings…:))
