old idea - new render with vray
Here is an old project - Working on the concept again - Comments to help realism?
I think I remember seeing your image posted back on the Viz Forums a while back, or perhaps C4D. At any rate, it definitely looks better.
The only comment I have is that in general there’s probably a bit too many reflections going on in the scene. The red paint seems a little washed out due to the amount of reflection.
Excellent model.
SunnyC.
Cool concept, If you need a test rider look me up :slight_smile:
I agree that the paint reflections are wrong, check the ior?
Also the swing arm looks like it would bend in a second, maybe a litle thicker and some bevels would give it a stronger look, also it looks like chrome I’d like to see it in aluminium.
On the same note, check the front forks they look to be about half the diameter they should be.
I wonder how it would handle :slight_smile:
i like the idea.
you should use some glossy reflections to make it more realistic.
especially on the environment.
also try to focus more light on the vehicle and less on the background.
use falloff map with costum fresnl curve for reflection! :wink:
shellac-Shader (Hot!)
robert
