Old Model test
So I thought I’d render one of my old models in Enscape and … damn!! the results are amazing.
I spent a couple of hours tweaking materials (there’s a lot of them) but when it came to rending them it spat out 50 1920x1080 images in 23mins!! Considering that I’m running Win10 in bootcamp on my i7 MBP with a below par graphics card I find that remarkable.
The model was made in 2011 and apart from 1 material texture I changed nothing apart from editing the material properties for Enscape.
I have a fair bit of light leaking due to the way I originally made the model but I’m OK with it for this test.
Pano: http://panorama.enscape3d.com/view/rrwnihin/
Pano: http://panorama.enscape3d.com/view/hmr4dvay/
Pano: http://panorama.enscape3d.com/view/pvvxrmmq/
Photos of the real church after refurbishment: https://goo.gl/photos/1aSCDyzYVUbhwtRt8
A couple more because I couldn’t choose just 10 :slight_smile:
Great work. Thanks for sharing! :slight_smile:
Interesting, beautiful scene.
I would be very curious to see all your colored window materials based on emitters. It could be a boomer.
Also you could try to build a single low poly cover object around your model. Enscape is hiding complex parts during light and reflection calculation that cause unexpected lights and reflections.
Even though I told myself I wouldn’t do anymore on this model I couldn’t resist another go.
Micha, I took your advice and changed the stained glass windows to emitters and popped a box around the whole thing to prevent light leaking.
I also adjusted some of the materials and changed the time of day.
Much better
As a suggestion, try playing with the fog settings - see if you can get some cool light shafts?
I don’t want to start another new thread so I’ll just append my latest tests here.
This is another existing model that was finished recently.
Looks nice! I’d desaturate the grass a slightly and add a bit more yellow in the color. It’s a good habit to calibrate the vegetation greens so that they look roughly all the same in your scene.
Another project re-rendered:
https://www.pres.dma-ni.com/view/enscape-mackin-1529495497-1529495497
Same model rendered with my previous renderer:
https://www.dma-ni.com/dma_projects/dma_view_proj/?permalink=ballyblaugh-road-5
2 more projects rerendered:
https://www.dma-ni.com/dma_projects/dma_view_proj/?permalink=mary-street-drogheda
https://www.dma-ni.com/dma_projects/dma_view_proj/?permalink=strathmullan-house
Beautiful work! These images have a nice quality, quite print-ready. Well done. :thumbup:
