Omni Light with Volume Light can't emit any light and produce NaN on v4 RC4
Corona v3 hotfix 2 is working fine, but it still have NaN. But Coronav4 RC4 can’t emit any light and produce NaN.
The project file is already uploaded with private uploader. It is 1559802322_can-t-emit-any-light-and-produce-NaN.7z
Thanks for reporting this to us.
I’ve looked into your scene, and the light appears to work if you switch the on checkbox to off… could you try switching the light off and see if it works?
We will investigate why this is happening.
Thanks,
Rowan
(Internal ID = 360549407)
Yes, it works. But you need to render first with the checkbox ticked, then untick it and render again to make the light works. But the NaN in the blue area is still exists.
