One click relink
Kind of like indesign, how’s about a button that, rescans and relinks to your map directories. For me, I am having to move model files around and thus, I break links constantly. Was curious if this functionality exists, or if it is in the works, or if this is just dumb and stupid?..8)
Re: One click relink
Currently the system uses a search paths that are generated from the paths of loaded content. If the content isn’t found in the original location, then those search paths are used to try and find the assets in question. You can add a search path by remapping a single asset to that new folder, then all the other assets in that folder will be found.
There have been a number of requests for several repathing/project path tools, so I would like to make this work much better in the next full version. I’m not sure whether your wish can be wrapped up in some of the others that are out there, but I’ll put it on the pile.
Search paths and the “hidden pack&go” are the great helper now.
http://forum.asgvis.com/index.php?topic=5902.0
