so, like the title says. We have one machine that is configured identically to 9 others that just won’t read certain .vdbs. It says:
[2019/Jan/4|14:23:05] V-Ray: Frame data 141000 successfully loaded from \\akashi\proj\apollo11\cache\fumefx\faster_main_bo oster_4b5\faster_main_booster_4b5_####.vdb.
[2019/Jan/4|14:23:05] V-Ray: grid 185x1248x185, cache index -2147483648.
[2019/Jan/4|14:23:06] V-Ray: Frame data 1240000 can’t be loaded from \\akashi\proj\apollo11\akashi\warehouse\apollo11\c ache\fumefx\left_smoke_4\left_smoke_4_pp_#.vdb.
[2019/Jan/4|14:23:06] V-Ray: No simulation data for frame time 2340!
[2019/Jan/4|14:23:06] V-Ray: Frame data 1240000 can’t be loaded from \\akashi\proj\apollo11\cache\fumefx\right_smoke_3_ 1.0\right_smoke_3_1.0_#.vdb.
so it reads one from a network share, then it doesn’t read another a different one. If I open maya on the machine, the volumegrid vdb selection input is blank. I can pick the .vdb and it loads, then if i save the scene and render it doesn’t load. These shares are on the same centos 7 box using samba, and like i said, all the other machines are perfectly fine.
Our VRay installation is loading from the network, so all the machines are using the same version, the hotfix 1 next. The maya versions are all 2018.4.
Is there anything else anyone can think of that would cause this. It’s driving us crazy.
