One node problem
Hi Guys… i have this issue and i can’t find the problem. Can help me plz?
One Node connect but says Node is not Responding.
And Show this.
Pd: attached Log file
The scene it’s very heavy! and the others nodes connect fine.
vraylog.rar (672 KB)
Does the same problem happen with lighter scenes? Also - seems to me that the log you’ve posted is from your workstation, can you post the log from the problem node also? If you have “Restart servers on render end” option enabled - please turn it off for the tests, otherwise the log will be generated anew every time. Have you tried running the DR job only to the problem node? Sometimes if you have a big scene and lots of assets you can hit a network bottleneck when transferring all the assets, resulting in the node not being able to transfer feedback to the workstation. Once everything is transferred, however - it’ll show back online if that’s the case.
Hi Ivan!
Thanks for answer.
I found the problem but its very strange. Opensubdiv modifier cush the system on the node. If i eliminate the modifier the problems resolve.
