OnenEXR pases trouble in 1.5
The same problem as it was in the 1.4 at release. When OpenEXR saving, then open
in photoshop, all pases(no main) is broken. Look screenshot in atachment pls.
In 1.4 Hotfix 1 all ok.
Old topic .exr save trouble (black layers) - Corona for 3ds Max :: Help Required - Chaos Forum then in 1.4 HF1 it fixed. Now again in 1.5.
This problem is just me?
Developers. Tell me please. It’s bug. Or problem only me?
Your post went unnoticed for quite some time :smiley:
Please show the way you save EXRs. There are a lot of compression options with exr and I recall playing around with those and getting similar broken results, that was a long time ago though.
Sorry for overlooking this topic. That’s why it’s always best to contact us at https://coronarenderer.freshdesk.com/support/tickets/new
As SairesArt said - please tell us more about how you are saving the EXR - what settings are you using exactly?
At first i do that http://dl1.joxi.net/drive/2016/11/09/0017/2626/1178178/78/f858954540.jpg
Then i click “save” (not save all) http://dl2.joxi.net/drive/2016/11/09/0017/2626/1178178/78/8ddda7d0d4.jpg
Then open in PS. http://dl2.joxi.net/drive/2016/11/09/0017/2626/1178178/78/b846c4f03c.jpg (I use randomcolor plugin for exr pases).
http://dl2.joxi.net/drive/2016/11/09/0017/2626/1178178/78/7e50409139.jpg but previous corona render version save EXR correctly. And my PS open it correctly too.
That’s problem =)
Can you make sure that this is the ‘broken passes exr’-thing again? There are one or two threads about this here in the forum.
This is a max-bug when saving the exr. It happens in other renderers as well.
Have you tried not checking ‘auto add passes’, but clicking on ‘add’ and manually adding your passes?
old bug report we were unable to reproduce, closing down. AFAIK there were some fixes to photoshop loading of EXRs in 1.6
