We still have big problems with our farm, to the point that we no longer rely on it. In the render window it just says “Render starting”, “connection problems”, repeat. On the farm computer it starts to load the scene, then says “terminate_soft” and repeats. One of 9 of our farm computers works, but they’re all identical both in hardware and in software (installed from an image). Any ideas? I’ve thought I’ve fixed it a couple of times, but even if it seems to work for a while, it always eventually fails and keeps failing.
Does it help if you restart the DR server application?
Have you already contacted us at support@corona-renderer.com ? (we have a similar report open, just not sure if you are the reporter)
No, restarting the DR server doesn’t work, it just goes back to the same loop. Sometimes it helps for a while to restart the whole computer, but not on every computer and just for a day or two. And no, that was someone else.
Please contact us about this at support@corona-renderer.com (if you haven’t yet) and include all DR and BB logs as instructed here: https://coronarenderer.freshdesk.com/support/solutions/articles/12000002065
