"only in secondary" for GPU rendering by a trick
“only in secondary” isn’t supported by GPU rendering. One of the most important options for my daily work. But I found a simple workaround since clipping planes are supported. Simple create a clipping plane for the needed objects only by setting the clipping plane in “Include” mode and choose the objects to be hidden (needs to be named before). Now, the clipping plane needs to be place behind the scene and all named&choosed objects are invisible. :slight_smile:
-Micha
