Only one irradiance map pass ... ?!
I recently face a simple but annoying problem with the last scene I am working on: although I set Irradiance map Min/max rate to -5 / -2, VRay calculates only one prepass …
I can’t figure out why: does anyone have an idea ?
Thank you
is ‘multipass’ unchecked in the ‘advanced options’ of the irradiance map?
No it is checked:
Is distributed rendering turned on in the settings tab?
Yes it is.
When DR is active IM is calculated in a single pass.
I didn’t know that, thank you.
How does it work ? Let’s say I set Min Max rate to -5 /-2 for the IM and I turn On DR. IM will be calculated in one pass with a rate of -5 ? -2 ? I am curious to learn more about that.
Yes - each bucket will do its own prepasses.
OK so can you please confirm that calculating a -5/-2 non DR IM will give the same result as calculating a -5/-2 DR IM ?
It will be very similar, yes.
Thank you.
