Just an question…
How can I re-render just a simple pass without the BEAUTY pass ?
The render is done, but after I need for example 2-3 AO pass more…how can I do that ?
Cheers
Just an question…
Cheers
its better to render AO with main pass by using CTexmap (see cTexmap file) but if you want to render only AO in new scene i suggest you to use my settings in AO.max file .
cTexmap.max (212 KB)
AO.max (208 KB)
Actions->render only passes
Thank you Keymaster!
That’s exactly what I lookin’…
Now I tried to got an re-render of the reflect pass with actions - render only passes , and that’s not working. With AO it’s perfect, but other passes not working…
Any advice?
Of course it is not working, because the reflection is derived from the beauty pass, so the beauty pass needs to exist for it to render. Only some passes can be rendered separately.
I’ve thought…Any chance the get something in the Corona like this…
http://www.turbosquid.com/FullPreview/Index.cfm/ID/757252
It would be so usefull, and great for testing how responding the material’s values in final pass…
