only the last frame will be saved as vrimg if I render several frames at once
If I render more than one frame in VFB only the last frame will be saved as vrimg.
Hello @oliver_zink ,
Do you mean that only the last frame is saved in VFB history? If that is the case, please check this and this forum topics where this has already been discussed.
thank you. the workaround is fine for me.
