I have a little problem.
On one file only, the VFB window appears in Bright Mode while the Asset Editor window is in Dark Mode.
How can I switch the VFB window back to Dark Mode ?
It’s work now !
I switched to the Bright Theme. I closed and restarted Sketchup. Then I switched back to the Dark Theme. I closed and restarted Sketchup again and it works.
Do you know of this “bug”?
Hi DCHA34,
This is a bug.
The VFB doesn’t have a bright theme.
This issue has happened to me once also but I can’t find a reliable way to reproduce it.
Please keep an eye for this and if you find the actions that cause it, please let us know.
Konstantin
