hello, im trying to download enscape on my windows laptop but this shows up
Hi @latoofa , welcome to our Forum.
Could you kindly in this case click on “log details”, copy what will be available and send it to our support team as detailed here directly? Then we can investigate the cause behind this in detail. Thank you in advance for your cooperation as well.
Meanwhile just in case you haven’t already you can also make sure that your machine meets our system requirements here.
Hello, my Enscape is also showing the same error message.
“The detailed log information” shows the following content:
Create C:\Program Files\Enscape\RendererHost\Renderer\Bin64\nvngx_dlss.dll
Create C:\Program Files\Enscape\RendererHost\BuildingPerformance.runtimeconfig.json
Create C:\Program Files\Enscape\RendererHost\Data\Sounds\restaurant_crowd.mp3
Create C:\Program Files\Enscape\RendererHost\Data\Sounds\clap_long.mp3
Create C:\Program Files\Enscape\RendererHost\Data\Assets\rpc_mappings_revit_sample_content.xml
Create C:\Program Files\Enscape\RendererHost\Data\Assets\enscape_categories.xml
Create C:\Program Files\Enscape\RendererHost\Data\Assets\category_mappings.xml
Create C:\Program Files\Enscape\RendererHost\StandaloneFileList.txt
Create C:\Program Files\Enscape\RendererHost\StandaloneEnscapeSettings.json
Create C:\Program Files\Enscape\RendererHost\Enscape.StandaloneHost.bin
Create C:\Program Files\Enscape\RendererHost\Enscape.StandaloneHost.runtimeconfig.json
Create C:\Program Files\Enscape\RendererHost\Enscape.StandaloneHost.deps.json
Create C:\Program Files\Enscape\RendererHost\EnscapeSettings.json
Create C:\Program Files\Enscape\RendererHost\Data\Horizons\whiteGround.ktx2
Create C:\Program Files\Enscape\RendererHost\Data\Horizons\white.ktx2
Create C:\Program Files\Enscape\RendererHost\Data\Horizons\urban.ktx2
Create C:\Program Files\Enscape\RendererHost\Data\Horizons\town.ktx2
Create C:\Program Files\Enscape\RendererHost\Data\Horizons\site.ktx2
Create C:\Program Files\Enscape\RendererHost\Data\Horizons\mountains.ktx2
Create C:\Program Files\Enscape\RendererHost\Data\Horizons\forest.ktx2
Create C:\Program Files\Enscape\RendererHost\Data\Horizons\desert.ktx2
Create C:\Program Files\Enscape\RendererHost\Enscape.RendererHost.runtimeconfig.json
Create C:\Program Files\Enscape\RendererHost\Enscape.CustomAssetEditor.runtimeconfig.json
Create C:\Program Files\Enscape\RendererHost\Enscape.CustomAssetBatchImporter.runtimeconfig.json
Create shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Chaos\Enscape\Enscape Custom Asset Editor.lnk
Create shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Chaos\Enscape\How to start Enscape.url
Create shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Chaos\Enscape\Change Chaos license settings.lnk
Installing .NET Framework 4.8
SketchUp registration failed (1073740286)
Settings registration failed (1073740286)
You can Ignore the registration error(s), but Enscape might not function properly
Contact Support and provide the files from C:\Users\WINDOWS\AppData\Local\Enscape\Logs\Enscape.Installer
Installing Chaos Certificate for All Users
Create C:\Program Files\Chaos\VRLService\uninstall\vrol_install_light_weight.xml
Create C:\Program Files\Chaos\VRLService\uninstall\install.log
Create C:\Program Files\Chaos\VRLService\uninstall\installer.exe
Create C:\Program Files\Chaos\VRLService\uninstall\backup.bin
Create C:\Program Files\Chaos\VRLService\docs\license_vrlservice.rtf
Create C:\Program Files\Chaos\VRLService\uninstall\icons\icon.png
Create C:\Program Files\Chaos\VRLService\uninstall\icons\bullet_unavailable.png
Create C:\Program Files\Chaos\VRLService\uninstall\icons\cross.png
Create C:\Program Files\Chaos\VRLService\uninstall\icons\tick.png
Create C:\Program Files\Chaos\VRLService\uninstall\icons\arrow.png
Create C:\Program Files\Chaos\VRLService\uninstall\icons\bullet.png
Create C:\Program Files\Chaos\VRLService\config.example.yml
Create C:\Program Files\Chaos\VRLService\vrol_install_full.xml
Create C:\Program Files\Chaos\VRLService\vrol.exe
Create C:\Program Files\Chaos\VRLService\vrlsupervisor.exe
Create C:\Program Files\Chaos\VRLService\vrlctl.exe
Create shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Chaos\Chaos License Server\Start Chaos License Server.lnk
Create shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Chaos\Chaos License Server\Stop Chaos License Server.lnk
Create shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Chaos\Chaos License Server\Manage Chaos License Server.lnk
Create shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\Start Chaos License Server.lnk
Create shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Chaos\Chaos License Server\Uninstall Chaos License Server.lnk
Create shortcut C:\Program Files\Chaos\VRLService\uninstall\Uninstall.lnk
Firewall: Added exception for application: C:\Program Files\Chaos\VRLService\vrol.exe
Create C:\Program Files\Chaos\UnifiedLogin\uninstall\installer.exe
Create C:\Program Files\Chaos\UnifiedLogin\uninstall\ula_install.xml
Create C:\Program Files\Chaos\UnifiedLogin\uninstall\install.log
Create C:\Program Files\Chaos\UnifiedLogin\uninstall\backup.bin
Create C:\Program Files\Chaos\UnifiedLogin\images\icon.ico
Overwrite C:\Program Files\Chaos\UnifiedLogin\ulasupervisor.exe
Overwrite C:\Program Files\Chaos\UnifiedLogin\ula.exe
Create C:\Program Files\Chaos\UnifiedLogin\licenses.json
Create shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Chaos\Chaos Unified Login\Start Chaos Unified Login.lnk
Create shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Chaos\Chaos Unified Login\Stop Chaos Unified Login.lnk
Create shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\ChaosUnifiedLogin.lnk
Create shortcut C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Chaos\Chaos Unified Login\Uninstall Chaos Unified Login.lnk
Create shortcut C:\Program Files\Chaos\UnifiedLogin\uninstall\Uninstall.lnk
Firewall: Added exception for application: C:\Program Files\Chaos\UnifiedLogin\ula.exe
Firewall: Added port 30301
Hi @pigheado3o and welcome to our Forum.
As long as your machine meets our system requirements detailed here please also reach out to the official support team directly for further assistance: How do I contact Support? - News & FAQ - Enscape Community Forum
We may have to ask for any further information from there after the case has been created, but this is the best way to get this resolved as quickly as possible. Thank you in advance.
Excuse me, have you solved this problem?
