Which FPP version are you using? I cannot confirm this with FPP 6.2.2, Corona 5, Max 2016. Maybe you could attach a simple scene? And if it’s a crash - the minidump of course ![]()
Good Luck
Good Luck
Checked, and I can confirm a crash in Corona_Release.dll (integer division by zero). But since FPP 5.0.5 is a four years old plugin I cannot judge if something will happen here at all
Corona v6 crashes as well with that version.
Good Luck
So it happens only with the older Forest Pack, and doesn’t happen with the newer version, right?
Correct. But there are enough issues with the newest version of FPP and Corona to go berserk.
Good Luck
Did someone report them? ![]()
Me not, currently I’m done with it. Exhausting to report stuff every release which should be found by QA within minutes.
Good Luck
Whose QA?
(internal id=498699142)
