opacity inside vraysss2 doesn't work
I don’t know if this was reported before.
but inside an object with a vraysss2 material applied you cannot render another object with an opacity map. the effect is ignored.
best regards
themaxxer
Can you post an image of what you are trying to do?
I have particles which should fade out with a opacity map. the particles are insaide a solid object (water) with a fastsss2 material.
when I render the scene with the water object hidden, then everything works fine (particles invisible) when I render the scene with the water object visible then the particles are visible, too.
best regards
themaxxer
Seems to work for me; can you post (a part of) the rendered image?
