( open ) [ HOU-2519 ] Vray Environment Fog
Hello.
I have tried setup simple Environment fog effect, like in 3ds max for example. And didn’t find way how do to this! I have created Vray Environment Fog node in mat network. I use in my scene Dome Light and one direct light. I didn’t find any gudilince in help docs and on the internet as well how make it appear on my render :slight_smile: Maybe you can give me a way or example how to use it? I find only one tutorial with using Volume Grid Shader but it;s not good solution for big scale scenes.
Hey. Fist you need to create V-Ray Environment node in the OUT context and point the main V-Ray ROP to it(see attached image) Then you create the fog node inside that environment node and you`re set.
Also, if you want per-object fog you could connect “V-Ray Fog Effect” to the “Volume” input of the “V-Ray Material Output” (you’ll need to adjust material opacity to make it visible though).
Thank you guys!
I cannot get that to work at all.
What do you mean adjust the opacity?
I tried exactly that but no dice.
Set 0 opacity in the material assigned to that object.
Hmm it doesn’t seem to be working for me. I am away for a week now, will see how much of an idiot I am on my return…
Hi @Jim_Meston , what are your Houdini and V-Ray versions?
You could check the example I uploaded here.
EnvFog_perObject.zip (36.6 KB)
Sorry for the delay, that is working. I am not sure why it wasn’t working. I have up versioned since this original query but equally it could be user error… scale vs distance parm etc.
Hello. Can’t make work fog again. just simple setup but fog doesn’t appera. Tried on new scene, no results
Vray 5.0050.0 (from Nightlies) Houdini 18.5.499
Hello @Mikhalenko , the issue is a known and logged, but unfortunately not yet fixed.
