Hello.
I need some control over my lines with the toon effect and the “Material Edges” seems a good option to play with it. Sadly its’ not working at all in my tests.
Could you confirm this is broken or am I doing something wrong?
I attached a scene in case it’s of any help.
I’m doing more tests and it seems “Depth Curve” option is not working neither. It does nothing when I activate it?
Depth curve and an angular curve seems not to work, I’ve added the issue in our system, should be easy to fix. But rest is ok on my end.
Material edges is working for you?
Yes, but in order to work you need to add a “V-Ray Material ID” node into your shaders.
Oh I see. Didn’t notice the need of ID. Thanks!
