Unfortunately I was a little bit quick with the pscale attribute and noticed a strange behavior.
Until now we controled the lights with the “scale” attribute which has 3 components. So we could shape the proportions of the lights. Now with the pscale this is a little bit cumbersome.
You see if we use pscale as a vector (what maybe does not make sense but apparently its the only working attribute for the light size at the moment?) and change the x component it also has effect to the y component.
To only scale lights randomly or scale them proportional is not what we want. We need control for the x and y.
Switching the control for the lights from scale to pscale makes a lot of our scenes to not work anymore and it would be nice if you can help us with a quick solution. We would prefer to stay with vray6 rather than switching back to vray5 because of that.
Hi @Jon3D , you are right, v@scale seems to be ignored after 8.august . I’ve reported the issue in our system and set its priority to “major” . Will write you here once it is fixed.
@chakarov Could you please take another look at this? It seems to be functioning properly with one point, but when there are two or more, it behaves erratically. The orientation is off, and the lights are no longer visible. If it’s possible, I would greatly appreciate a speedy resolution. Thank you.
thank you for providing the scene. After reviewing it, I have identified that the issue arises when using a rotated light. Rotating the light can cause unexpected behavior with the first light and it will be ignored by the others. That was the problem in my example scene. I changed your scene by using four lights with the N attribute. As you can see in the image it only effects one light.
Thats good to know and a workaround for now but, changing the rotation of the lights can be a quick method to alter the direction of the lights (as it was possible before) instead of modifying the normals. I think it would be worth looking at this again. I believe it does not work as intended?
Btw. the light itself has always to be turned off even if its not included in the rop node. Otherwise it will be included in the rendering. (small issue but just wanted to mention it)
To inform the community (we have already cleared out the difference between builds in the opened ticket) > 22404 = stable nightly build 22405 = nightly build
The fix will be included in the upcoming Update 1 too ")
In addition, while looking at your screenshot - you have looked at Latest section - that’s why all the V-Ray 6 for Houdini builds are shown in one section.
To avoid misunderstandings, please pay attention to the separated sections in similar situations:
