[OPEN] [VC4D-1189] switching off the Render Elements when rendering in Viewport
Is it possible to add the option that when rendering in the viewport all render elements are automatically deactivated and when you are done with the viewport rendering activated again. If many render elements are active the viewport render does not work very well anymore. If I always do it myself, it could happen that I forget to do the final rendering and that would be very annoying. Also I would be very happy if the Edge Trimming and the Texture Solo Mode would be included in the next update :slight_smile: :-)!
Hello @sven_nussbaumer
Thank you for the idea. Could you please describe what does “If many render elements are active the viewport render does not work very well anymore.” mean in more details? You could share a screen-recording if possible.
https://1drv.ms/v/s!AliLeuERapgHg-hWK88u\_Hkd-8Rp4w?e=j2PyH5
Thank you @sven_nussbaumer we have logged this in our system [VC4D-1189] You will be contacted if the matter is further developed.
Hello @sven_nussbaumer I would like to inform you that the improvement has been implemented in the latest Stable Build you can find here: Chaos
Wow! Thanks for the quick implementation! Now it runs exactly how I want it!
Glad we were able to help, @sven_nussbaumer
