hou can I open a vray raw image???
tanks,
112
tanks,
112
Re: open VrayRAW
and what is the max pixels I can juse to render as a HDR or JPEG??
Re: open VrayRAW
you will need the Vray Image to EXR converter that should be available for download in the tools section. The converter is all command line based, no graphic interface, so you’ll need to start up the application and type in the path. From there it should take care of the conversion, and there are instructions that appear if you want to do more with the image. I think I have also just set it up to automatically convert a vrimg file by right clicking on it and telling windows to open it with the vrimg converter.
Re: open VrayRAW
…or you can just drag and drop the file onto the exe.
