index
May 8, 2018, 9:34am
1
this might have been posted already…
on macosx sierra sometimes materials are not displayed correctly in the viewport
(ie displayed in a bright green instead of rendered with texture)
re-rendering the material does not update the display
the only way to get a correct display is to close and reopen the file.
which also does not work in all cases, sometimes you must try a few times
Hi, does turning this on and off help?
bet its some fucked graphics driver
iacdxb
May 11, 2018, 12:30pm
4
Yes… it is.
open file again… and used texture shows in some different solid colors… even in Sky, use hdri shows black.
I dont think its becuse of graphic driver…!
open old corona file and sky is pink…!
have you even tried the driver update? I’ve had similar issues a few years ago that forced me to keep to a specific version, or otherwise my viewport would turn crazy.
Not seen any driver update issue for Mac Pro 2013.
.. and sometime its black.
Is the library preset actually correctly linked? You mentioned an old scene file, so maybe the libs are pointing to another location or it’s even missing.
but It renders fine…! If its not linked correctly, it will not show in render.
not this only… some time textures shows in different colors even it is correctly linked.
iacdxb
May 17, 2018, 4:06pm
10
Mostly it changes colors in R19.
Grid is in pink color.
does this happen in software rendering?
