When using vray fur with Area distribution + Fixed areas + OpenSubdiv I get artefacts when rendering
(interactive render shows no artefacts though)
maya 2024 vray 7.1
I have attached a small test scene.
When turning any of the attributes “vrayFurProperties.fixedAreas” or “vrayDisplacement.vrayOsdSubdivEnable” to off it works as intended-but i need to use OpenSubdiv to be able to use the fur
I have never encountered this before using vray 7
Is there a workaround or am I missing something here…
Thanks for the report. The issue is reproducible. I’ve logged it (internal tracker ID: VMAYA-13723) for developer investigation. I don’t see any other workaround except disabling Fixed areas…
Thanks!
The only workaround i found to hide the issue is increasing the subdivs to a high number which shrinks the problemtic area until its not visible anymore while reducing the fur amount.
But obviously this is not a proper solution.
have you tried using the regular v-ray subdivision attitude instead of OpenSubdiv? I generally just use the OpenSubdiv attribute as well, but I remember in the past sometimes the regular subdivision attribute would affect things differently.
