Optimising scenes in Next
Hi guys,
With Next, is there a tutorial / workflow to optimise scenes? Is Grant Warwicks still the way to go, even though it’s outdated and relies on changing settings (ie material subdivs) that are otherwise normally not changed?
My problem is that my interior scenes seem to be taking an age to render, much more than expected, and to be honest, more that I’d have expected in Vray 3. I’ve re-built all my rendering files using Next, so I’m not bringing incorrect settings from vray 3.
Any links for advice would be appreciated.
Thanks,
Dean
I think Grant’s way is really outdated, but will probably still work. I just did a series of interiors and my render times were amazingly fast. Some of the spaces took 15 minutes, which were 2k images. You have to make sure your camera and light settings are true to real life.
Also get a 10.000$ machine ;-);-):wink:
Ouch, that hurt! :slight_smile:
L…o…l :d
This is definitely outdated. I haven’t seen anyone get better render times with this approach lately.
My problem is that my interior scenes seem to be taking an age to render, much more than expected, and to be honest, more that I’d have expected in Vray 3. I’ve re-built all my rendering files using Next, so I’m not bringing incorrect settings from vray 3.More information will help. If you can get me a scene to vlado@chaosgroup.com I might be able to give you some pointers.
lol Grant Warwicks methods only work if you have no deadlines and access to 140 machines with DR !
I have been restarting my 3.6 scenes in Next and have in some cases got cleaner images, faster mainly when using atmospherics and HDRI lighting
Hi Vlado, email sent :slight_smile: Thank you!
I would be interested in this , so please share your finds here too :slight_smile:
Hi, Just wondering if anyone has any thoughts on this? Just a bit lost as to where to start optimising scenes in Next?
Cheers
I think V-Ray NEXT does it for you now. There really isn’t much to do. I run a few scripts as a habit, but it’s nothing V-Ray NEXT isn’t doing in RT.
OK, so what’s the optimal set-up? I render using buckets, CPU. Lighting is generally vray sun, direct lights, spot lights or vray plane lights. Hardly ever use HDRI.
I have 1/24 0.01 and everything else as standard.
I have no direct comparisons between vray 3 and next, but I get the feeling, especially on interiors, that my renders are taking too long for an acceptible level of noise.
Whats the resolution of the image and what is the time you think unacceptable
Yes, interiors for me are a nightmare on render times, too, using CPU. I switched to GPU Hybrid to get around the high render times. With CPU my interiors were 2-3 hours. With GPU Hybrid, it’s less than 1/2 an hour.
5k resolution, over 12 hours per interior.
Can you upload the file ? or wetransfer ?
I’ll see what I can do, but need to be careful as it’s a live project.
Also, after some testing, by ticking “Use local subdivs”, I get better render times, and no noticeable different in noise in certain scenes,
I suggest this option to be removed in future releases. It does more harm then good. It may work on some simple corner cases, but on the majority of scenes it is likely to perform worse.
IDK, that automates V-Ray now and reverts it back to the old days, doesn’t it? It’ll smartly assign the subdivs per object internally.
Yes, V-Ray does this on it’s own these days.
