Does this mean we no longer need this script…http://forums.chaosgroup.com/showthread.php?45291-proxy-memory-footprint-copy-vs-instance&p=399184#post399184 ?
I see. I bet that is the script vlado was talking about. I don’t think you need that one anymore, as VRayProxy objects that reference the same proxy file will not load the proxy more than once.
The one I was talking about converts EXISTING instances to VRayProxies that all reference the same file. (I think it also instances them in Max for convenience, but this is not needed anymore from a memory usage standpoint.)
Unless I am doing something where I need tons of high -res objects, like cloning rocks or trees I usually start with instances in Max, and then convert later. For cloning/scattering I would use proxies from the get-go.
