Option to completely disable warning / errors window on render setting ...
We do not want to do this as we think that errors are too severe to be ignored. Can you give us an example of error (not warning - those can be disabled), that you would like to ignore permanently?
Actually there is a way to get rid of error and messages window by modifying Corona settings file, but i wouldn’t advise to do so. It’s better to reduce its appearance by choosing to display errors only.
Those are warnings - not errors, you can easily disable them.
Ah crap, my bad.
ok, those can be switched to warnings… but try some leather presets, and it will crash :wink:
ok, switched those to warnings
Hi guys, I have one question I accidentally turned off Corona error log. Can some1 tell me how to turn that log on? I rly need them on render window or IR. I have also tryed with reset 3dsmax and start over everything and still no result with switching on.
How exactly did you disable it?
If you only clicked “ignore” then this should only work for the current session and if you reload your scene it should fire for the same error. Maybe you are simply not triggering the error?
