it would be very helpful to add an option to add bloom glare in the pass only (Caustics already has this option). This way when I render into PV via “Render Marked Takes to PV” command I still can save beauty pass without BloomGlare baked onto it.
Thank you.
That’s what the virtual beauty pass is for.
If you look at the image, although BloomGlare is disabled as a pass it still gets baked onto the background. Is it not understandable why one may want those passes separate, similar to caustics pass, that has this option?
Add the virtual beauty pass and uncheck bloom and glare, you’ll get your final image without bloom and glare.
Aah there, thanks.
