I’m trying to set compression of exr files using the OptionRE element when using the Vray frame buffer with separate render channels selected.
Testing a few renders with DWAA and ZIPS compression set in the element, but the file sizes just stay the same on each render.
Saving directly to a raw vrimg file and using the VRimage to EXR convertor to select the compression works, but it’s an extra step if the VFB can write the compression directly.
What is the working method for this?
At the moment we just write exr’s using the 3dsmax file save (with vray VFB off), but I want to get the Denoiser and Cryptomatte elements as output files as well.
Thanks for any pointers!
