So sick of doing distorted wide angle lenses for tiny rooms that I tried my first section render [thanks to a flexible client] This unit was tiny & looked like S*&$ with a super wide angle lens, but ended up looking nice by doing a sectional render.
The only comment i’d have is that the reflection on the kitchen splashback doesn’t read too well. Needs a highlight or less reflection/milkier reflection so that it’s clear that it’s actually glass rather than looking into another room.
I agree totally! Unfortunately the client specs were that it is actually a mirror and not glass splashback [which is how I had it at first as I hate using mirrors in 3D for the very reason you specified]
As usual the clients get the last say.
Very successful. I don’t think we should be *ashamed* for using this kind of technique. Afterall, most TV dramas or films are shot on set with similar constraints. They just ‘knock-out’ a few walls or openings here and there to best show what is going on.
It is a key advantage to producing CGIs rather than photographs.
I’m not a big fan of sectionnal views but I have to admit that this one is really beautiful. All the details are well executed and the natural/artificial light balance is perfect (maybe try a slight blueish light for the daylight in post ?)
I agree for the flares and the mirror remarks, at first sight I tought “wtf, an half flat screen in the kitchen ?”
Nothing tricky about the setup--Just a focal length of 30mm & taken from about 12 meters away.
All the walls & props are in the scene for GI & reflections & the ones I didn’t want to see have ‘Visisble to camera’ property turned off. Just be careful that any objects not visible to camera DON"T have any double faces as it will cause black artifacts in the render. Even 2 separate walls with faces meeting at a common point will cause this.
I’m still not clear on what a sectional render is I guess. Is this done in one render, or did you render a couple of sections and stitch them together in Photoshop?
It’s just one render--no stitching required!
The section render refers to the fact that it is as if you have sliced the room open to see inside…maybe they should be called Sliced renders??? It has nothing to do with rendering in sections or anything like that.
I didn’t understand this clearly.
If I am not wrong, you have all the exisiting walls of your room and you put a camera very far from the room and you disabled the “visible to camera option”
Then did you delete bottom faces of the wall where it touches ground?
