I am used to Vray (3dsMax) and testing Corona:
I have problems with orbiting the camera, it should not rotate on all axes.
Is there a hotkey or another orbit tool?
Camera like any other object, certainly should be able to rotate on all three axis. If you want to prevent it from rotating on some axis, there are ways to do it, but it depends on the way you’re rotating the camera. Can you tell or demonstrate what you’re doing and what you want to achieve?
I am looking only for same behaviour like a Vray Camera.
But strangely in another sene today it is working… I did not find out what was different yesterday, when it always tumbled.
I will hopefully find out ![]()
