Organize, Sort and Rename Render Elements - Script
Hi
Recenlty in Corona forum an user shared an script that could Organize, Sort and Rename Render Elements, this is something that is missing in 3ds max for ages, Render Setup hasnt changed at all, is pretty old and is lacking of a lot of tools.
So this script works perfectly fine in Corona, but its not working with Vray, this user said that vray render elements have no name property and the possible solution would be a fallback to the class name as it is done in the collect section above and to test for the name property every time.
I dont even bother to do this in Vray at all, I always have my elements organized, but it could be nice to have it working in case I received a file from someone else thatt I need to work on.
I shared the script here in the case someone has interest on keep the script working on Vray.
Here you go. There is, in fact, a parameter for the element name (called .elementName). I just replaced all instances of .name to it and it works as expected.
RenderElementsOrganizer_v01.1.7z (1.86 KB)
@hermit.crab thank u so much!!!
