Orienting a timber floor
If I have applied a timber floor material to a floor and I want to make the timber run a certain way, is there a way of rotating the material on the floor?
Thankyou
This can be done in Revit:
  1. Associate an appropriate Model Pattern to the floor material that is oriented in the same direction as the floor material.
  2. In the project environment, select the Model Pattern (hover over the floor pattern and tab to select) and you can rotate the Model Pattern of the floor. This rotates the associated floor material.
