Origin of nested groups moving
I use SU - placing components with components and groups nested in them. When these are re-sized(stretched) while auto-update is on it throws the geometry in Enscape off.
This is simply fixed by re-loading Enscape, but there must be a glitch somewhere; I don’t want it to happen while prospective customers are watching me change sizes and re-sculpt their model.
@Gadget_1 Can you send us an example project and PRECISE steps to reproduce the issue? Would be a huge help.
I’ll keep an eye out and forward on the next time it happens. It’s fairly easy to reproduce (at least it happens to me a few times on every job I model.) I think it’s probably something to do with multiple groups having geometry nested about three or four levels deep; maybe its applying the transformation to more than just the intended object?
Update: just happened again… (feedback sent)
Update: it may be connected to the “Undo” action - just had things jump about when I rotated a component within a group, then undid the action.
Just to bump this; it’s still happening with the latest release (2.3.0.83-g01dda85)
(Second image is after re-launching Enscape)
{Edit:… I just noticed that the textures move too.}
{Edit: … Now this is weird - I just performed an undo two levels (undid the close group and fill actions that caused another off-set), then performed redo twice and it returned the geometry to the correct position with the correct fill.}
Hi Gadget, is there a chance you can share the project with us in which this issue occurs? Also, ideally, with steps how to recreate the problem. We’ll be happy to look into this!
@Kaj_Burival_1 I’m sure that there is an open ticket that I posted in before, but I can’t find the relating e-mails - I’ll add a drop box link if you can PM me a link to the correct ticket.
I fear the model itself won’t help if we don’t have exact steps for reproducing the problem.
@Gadget_1 Fixed in preview version 2.3.0.221-g193a420
(The previous thread was closed: Origin of nested groups moving)
Unfortunatly I can still do the same thing in 2.3.2.420-gdeb9705:
should be this:
{Ticket #56743}
#56743### #56743
That’s the often requested explode feature :wink:
We’ll have again a look at it, thanks for providing the needed data!
Update: Enscape-Setup-2.3.2.1147-g524138a
The glitch seems to have changed from moving whole components/groups to only moving individual points:
(Should look like this:)
Edit: The glitched geometry is attached to specific groups - when these groups are hidden by passing behind something in the viewing window, all the glitchy geometry vanishes to re-appear when that group is visible again.
The group that goes glitchy is not normally the group I’m editing: it seems to be some other group that is having (some) of the transformations applied to it when I’m actually editing another group.
(I just finished editing a piece of furniture and noticed that the house walls are now a cubist masterpiece, but the furniture has not had any of the changes made applied to it. In Enscape. It’s fine in SU.)
Update: Enscape-Setup-2.3.3.1493-g1875bae still happens.
@Gadget_1 still waiting for a repro case. Does not happen with the projects we use for internal testing.
I can say that this still happens on every model when I am editing the geometry (Enscape-Setup-2.4.2.2124-gd384852 SU18):
It can’t just be my setup can it?
@Gadget_1 I think this thread contains (at least?) two different bugs:
  1. Geometry that looks OK, but in the wrong place (Posts 1, 3, 5, 10). This was fixed in the meantime.
  2. Corrupt geometry added with some geometry missing. (Posts 12, 15).
When you encounter 1) again, please open SketchUp’s “Ruby Console” window and forward error messages appearing there to us. But since we fixed it I haven’t seen this bug again.
Regarding 2) I have re-added this bug to our internal tracking. I guess the bug occurs when you are modeling while Enscape is open with live updates in the background. When you click the “Start Enscape” button again, Enscape is fixing itself. There is no way to reproduce the bug. Is my evaluation correct?
Yes - Enscape open in the BG with ‘live updates’ on and re-loading the geometry fixes it:
Model is made of several groups and nested groups/components. When I create any geometry (eg steps in the above case) the first thing I do is draw a rectangle and make it a group. I then edit this group to create the end result (using native tools; no plugins)… this seems to be the only common action that produces this bug that I have found (so far).
Any time I deliberately try to reproduce the error I can’t. Any time I want to demonstrate editing and changing stuff on-the-fly with clients/bosses watching, I can almost guarantee that it will happen. (I have to rely on toggling scenes and visibility rather than actually changing any geometry.)
Oh, now I understand. It’s the presence of your boss. Enscape can feel the disturbance in the Force. :wink:
Thanks for the additional info.
@Gadget_1 Give the new preview version 2.4.2.2657-g263c05c a try!
