origRGB/EffectsResult: Inconsistencies when saving
Hey guys,
I got a little request here. First, I am happy that we got back the origRGB channel, because it was helpful to recreate the Master Beauty with Lens Effects applied this way.
However, the naming of that layer is inconistent, depending on how you save. Here is a short explanation:
Saving automatically after render end using the render dialog window:
- element name is “origRGB”
- RGB_Color has Glare baked in
- origRGB has Glare not baked in
---> totally fine as is
Saving manually from the framebuffer:
- element name is “effectsResult”
- RGB_Color does not have Glare baked in
- effectsResult has Glare baked in
---> this is a difference to automatic save
So, can this please be made consistent to the automatic saving of render elements?
Regards
Oliver
Hello, the naming for origRGB/EffectsResult channels is indeed inconsistent. I have logged an improvement task in our system under VMAX-11886.
Thank you.
It would be best if the RGB_Color had baked in the Glare in both cases, no matter if saved manually or automatically.
