I’m having a few issues setting up ornatrix. Wondering if that’s me who’s doing something wrong or what.
Problem number 1:
I am getting this error message once I hit render IF Hair From Guides modifier is applied. Sometimes it just crashes Max and sometimes I’m able to click continue, but usually it crashes later on anyways.
Problem number 2:
Color from base mesh/object not working (using bitmap). Although it should work straight out of the box as far as I know, since it should be the default setting. What’s interesting you can see in viewport it’s actually working as intended (hair’s getting color from base mesh), but in IR it’s not. The only way to make it work I found is applying Mesh From Strands modifier and un-ticking “Per Strand UV coords”. But IMO it’s just a workaround.
Any thoughts?
Thank You.
