Here is a script with the most often used parameters from Render Setting and a little from Material Editor
Script is in WIP. So a proposals and feedbacks are welcomed
Drag and drop Corona_tweaks_v1.xx.xx_dock.ms into viewport of 3dsMax with the same Corona Renderer version;
Open Customize>>Customize User Interface…>>Toolbars>>category:“Corona Renderer”;
Drag and drop action “Corona_tweaks” to panel;
Press button
Enjoy
Tested with 3dsMAX v.2014 and 3dsMAX v.2015
ps: If you want that panel was opened in one time with 3ds max you need to copy Corona_tweaks_v1.xx.xx_dock_STARTUP.ms into c:\Program Files\Autodesk\3ds Max 20XX\scripts\Startup\
If you need to do floating panel just move mouse on any border part of the panel and double click or open right click menu and click float
added button RegionRender On/Off - so now more convenience to use region render with Corona VFB; (fans of region render will appreciate it ) (;
moved “BitmapProxyMgr.globalProxy OFF” and “IBitmapPager OFF” into automatical actions when panel opens
added updating all of values from RenderSettings with any mouse motion under the area of panel in case of DB version and with left button mouse click by area of panel in A6/A7.2
I don’t know is this bug or not, but when i start this script i can’t select vfb type and change image filter.
Here is the video where i recorded this bug.
