We use orthographic cameras a lot, but have noticed a strange issue when we render using the VFB via our orthographic camera the render is constantly restarting despite nothing changing. If you switch the viewport from from the camera to a orothgraph viewport, it suddenly starts to work correctly as you would expect. It only seems to effect the orthographica camera (max camera).
Using 3Dsmax 2025 and Vray 7.1
Mind if you send a scene for this one, too?
I have just submitted a ticket with max scene and example video: https://support.chaos.com/hc/en-us/requests/372965 (please note we are using Vray GPU).
Thanks for the provided files. I managed to reproduce the issue and I’ve logged it (internal tracker id: VGPU-6799) for dev investigation. Not sure if there’s a workaround except either using Orthographic projection from the Settings, or Orthographic mode in the Viewport.
