hi,
can anybody please tell me how to change my vray physical camera to orthographic projection to render elevations of my model?
I tried :
- Set FOV to 1 with enabled physical camera, but its hard to find and positioning the Model perfectly
- tried to disable Physical Camera and enable parrallel projections in Sketchup but the colors arent exactly like with the pyhsical camera … but could be corrected in PS…
this works for me if i’m not in parralel projections mode … if i’m there i can’t find my model :
is there someting like “Save Frame” in SU?
So it there a native function in Vray? - if not this would be my number 1 on my wishlist
thank you
Re: Orthographic vray physical camera question
I think u just need to change your fov in sketchup to 1 leave it on perspective and it should work
Unfortunately our product has trouble with orthographic projection rendering, because V-Ray is physically accurate. Otho views aren’t physically accurate. That’s why you have to sort of fudge things a bit.
There was a trick that I think thomthom mentioned a while back to set the camera zoom to something like 4000. You still see slight converging, but much better then without. That’s the way I’ve been doing my plan views.
