when I am trying to load a OSL file, I get the following error message:
// Error: OSL shader error: Could not compile shader //fileserver/networkInstall/Vray/Maya2017/VRay36002/vray/opensl/jiWindowBox_VRay.osl (OSL to OSO) //
I guess Vray is unable to find oslc.exe.
How do I tell Vray where to find it?
Is there a preferred folder where to put the OSL files? Maybe the …\vray\opensl\ folder?
We are running Vray from a network location.
VRAY_OSL_PATH_MAYA2017_x64 is set to …\vray\opensl\
Maya 2017 Update 4
Vray 3.6.00.2
I’ve reproduced the issue here. It happens only when V-Ray is loaded from a network location. I’ll report the problem and check for a workaround then will get back to you with some more information. Thanks for the feedback.
