Osl map support
hello thanks for this great program, I’m using wparallax map, but unfortunately vantages don’t support it, please solve this problem. Thank you.
Hi bacaran,
Thank you for the feedback! I have added your request and will inform you when this feature has any development.
Alexander
Thank you for your interest, I’m looking for good news.
Full support for OSL will probably not come any time soon, as it’s quite complicated.
We can however implement just the “wparallax” OSL shader (in its current code state) and support only that (by guessing that the OSL being loaded is wparallax and using our fixed version).
Is this something that will be enough for you ?
Greetings,
Vladimir Nedev
Sure, this will be enough for me and many other users who are used to architecture, thanks for your interest.
Hello again,
I tried open wparallax scene may be that it will be open after 1.4 version new release, but it is crash.
and it gave this error warning
scene was showing even if it wasn’t supported in old versions
Can you please send me the scene or attach it here on the forum ? My e-mail is in my signature.
We need to fix this ASAP, but we need the scene.
Greetings,
Vladimir Nedev
Thank you, here you are.
Thanks for the scene. I can reproduce the crash.
It looks like an issue with the brand new VRayMultiSubTex support when it has sub-textures that are not supported - in this case the V-Ray OSL texture.
Greetings,
Vladimir Nedev
it probably is, it was working even though it didn’t show in previous versions.
maybe add wparallax support while solving the problem :slight_smile:
The crash is fixed in version 1.4.1 that we just released.
I am sorry, but we are working on some other large features, so support for the wparallax OSL shader will have to be done in some future release.
Greetings,
Vladimir Nedev
I see thank you, I’m looking forward to wparallax support, I hope it will be listed as soon as possible..
is there any update?:face_with_spiral_eyes:
Hi, i just purchased wParallax using normal vray in houdini. get straight crash too.
would love a fix for this, as i need this on a new job we just started! has anyone got this working in normal Vray yet???
Hi all,
No progress has been made to this request so far as it is not so high as a priority currently.
Does that crash happen to Vantage or V-Ray for Houdini? If it is only Vantage, I would suggest to not use it in the scene as it will not render in Vantage anyway. If it crashes V-Ray for Houdini, I would advise you to write in the V-Ray for Houdini forum section:V-Ray for Houdini :: Issues - Chaos Forum
Alexander
Oh yes… super helpful. must have 8):sunglasses:
is there any update for this? Or alternative parallax method in cosmos?
or this :slight_smile:
Hi bacaran,
An alternative for parallax interiors is what Lindalë are doing with RoomBox for Sketchup. You have to model a cube and relevant internal planes and map them accordingly to the room parallax texture. I have made a sample scene here with the aforementioned cube and 2 of the free samples provided by wParallax: https://drive.google.com/uc?id=1TtuFF3Db5BZyFacM5HQKiRLndBbmBrSK. Please check it and tell us if this workaround works for you.
Alexander
