Hello.
Not sure if this has happened before and could not find it in the search function. However, 3dsmax 2012 64bit seems to crash when I try to render files that have a higher height then width. Even playing with the render settings and rendering a normal HD image seems fine most of the time, though in some instances even that has crashed during testing.
( for Images above 2k.) The file takes around 5gig while rendering and my machine spec has 16gig.
It renders fine on 800x600.
Thanks for any advice.
which Corona version do you use?
Alpha 5.
Darn, I did put a cheeky Alpha 5 tag on the render dialogue.
My guess is that this is a problem of the framebuffer in A5 I already fixed. Try this again when A6 is out just to be sure, but I feel that the problem is already fixed
Yes, as I do have the same issue with other files using a higher vertical height. If the file is simple it renders but with more geometry it would crash.
I will wait for A6 and thanks for the super render engine, makes life easy for guys like me. :]
