Sometimes when doing diagrams some elements are more important than others.
So I need some geometry with the outlines and some without.
Is it possible, besides the Outline setting, to have also an Outline material?
Thanks!
Thanks!
Hey @FloatingVolume , thanks a lot for your inquiry. While this isn’t possible yet, in case you’re asking, I can gladly file this as a corresponding feature request.
Let me know in case there is anything else you want to add to it!
@FloatingVolume meanwhile you can use the material ID export option to easily create outlines in post production.
More info: https://enscape3d.com/knowledgebase/saving-a-screenshot/
@Demian_Gutberlet , thanks! Besides lineweight option I can’t think of anything else.
@Alexander_Devaykin , using the ID is a good trick. I just try to avoid post-production because the design changes many times.
Ok @Demian_Gutberlet , I have another suggestion, besides line weight we should also be able to set it to dotted-line pattern. Super useful for diagrams!
Thanks!
Thanks @FloatingVolume , I’ll add it to the feature request! ![]()
@FloatingVolume Do you know the Rhino ApplyCurvePiping function? It allow you to render all curves as pipes. You can define the thickness and the pattern (dotted lines, …). Rhino creates light weight low poly mesh pipes for rendering only, the mesh geometry doesn’t need to be saved to the Rhino file. You could apply any material, if you use emitter materials you get a line effect without shading. Maybe it’s a good workaround. (I hope Enscape support it. If not, you need to extract the render mesh before.)
Other than line weight, you could also have a Colour variable - I can think on a few options:
Black (single solid colour for all lines - choose the colour)
Inverted
Object/face colour (line colour dependent on the object it’s outlining)
You could also have a special fill or tag that outlined one entity so that you could put a ‘sticker like’ or ‘cartoon’ border around something. (I might have stolen that idea from someone else… I think there is a blender “2D” mode like that.)
Thanks a lot @FloatingVolume and @Gadget_1 , the further feedback has been added to the request.
