Outlines - exclude layers/objects/materials
Hi! Is it possible to add in some hotfix this feature?:
To be able to exclude/include layer/object/material in outlines mode. Withouth this is problem wit greenery which have too many outlines (especially leaves, etc…).
Pavel
​Hello, Pavel,
The Outlines effect can be altered or excluded individually for each scene material.
Here is an example of a very simple model with Outlines effect enabled (the tree is a Cosmos asset).
Here are the steps needed to exclude the tree from the Outlines overlay:
  1. Merge the Cosmos asset to get access to its materials.
  2. Select one of the Tree materials and add an Outline attribute:
  3. Lower the Outline attribute’s opacity to 0:
  4. Repeat the previous two steps for every other material used in the tree asset.
End result:
Hope this helps!
