Outlines in viewport not the same as in capture?
viewport:
capture:
enscape 2.5.2
@FloatingVolume , this is a known issue which will be resolved with our next preview and upcoming full release. :slight_smile: Thanks for the report still. If you want to avoid this behavior altogether, I advice downgrading to 2.4 temporarily.
Ok, good to know
I found the output of v2.6 is quite fine too, if outline thickness is set to 0% and the slider moved an invisible tick per right arrow button. The slider shows still 0%, but there is an outline at the saved output. Maybe not so thin like in the past, but maybe usable. I use v2.6preview for my current project and it’s quite stable so far I have seen.
Here an example of a 3000x1500 shot:
This works perfectly, especially when you use white models in first phases of project! Thanks
